What are these
dyoung14
Is getting worn out
spencer,tn
ARe these wheel anything special? what brand are they? And there a steel wheel
GenLightening
Yeah, it's a CHEVY!
Pukalani, Hawaii
I second the trailer wheel. The way the center is shaped where it connects to the rim is the giveaway. What size is it?
dyoung14
Is getting worn out
spencer,tn
its a 16 inch wheel, im thinking about putting them on my truck, they will work fine on a truck wont they since there a trailer wheels?
argve
Resident Fruitcake
Gwynneville, Indiana
they should have stamped in them the weight rating shouldn't they... I would say if they are the right weight rating and they bolt up and the hub fits good it shoudl be a go.
GenLightening
Yeah, it's a CHEVY!
Pukalani, Hawaii
Usually they are narrower for trailer use (6"-6.5"), but check the load rating to make sure they'll be OK.
dyoung14
Is getting worn out
spencer,tn
They fit just fine, and have 265/75/16 tires on them, i will look over them and see if i can find a load range
LCAM-01XA
my very own hell
These are the wheels you usually find on the 7000 lbs trailer axles. I'd imagine they will be just fine in your truck
crispy74
