BigRigTech
Diesel junky
A ZF is rated for 550ftlbs of torque and a much simpler setup....I find my 3.55's with the ZF is just right on the highway....A little lazy loaded heavy but overall pretty decent.
Not too sure about the spicer, but the US gear can be left in overdrive all the time or you can shift it in & out. The Gear vendors is a clutch unit like an auto trans & the Us gear is a gear driven unit.
Just wondering about those Spicer 5831 units, can you keep them in overdrive and stop. I remember hearing that on gear vendor overdrives it wrecks the unit if you go below a certain speed, is this the same for the Spicer?
I think it would be pretty dang killer if I had my t-19 shifter, my T/C shifter, and a Spicer shifter setup all in there. Might get a little confusing, oh well
The spicer auxiliaries couldn't care less what gear you leave them in, you aren't going to hurt the things . These things are the old brownie boxes out of big trucks, the 5831 is one of the smaller ones used in dump trucks and short log rigs and the like. it's a non syncho box so skilled shifting is involved( i.e. gotta learn how to float gears like a big truck driver or do the double clutch routine enough to fudge them in)
If you leave it in OD and stop it wont hurt anything, OD and 1st might just be the perfect takeoff gear if pointed downhill.
I kind of figured with an unmarked shiftknob parking the thing in UD would make for an extra theft deturrent. if anyone tried to steal the thing they wouldn't be able to go more than about 15 mph
Floating gears is when you shift out of gear without using the clutch, and then match the rpm's to the speed of the tranny for the next gear, then you slide it into gear without the clutch, right? If it is I can do it . Its not all that hard to do at all.
If you can float gears on a synchro box... where you aren't supposed to , you wouldn't have any trouble at all shifting a brownie
Come on now, I havent done it in a while. I remember the first time I did it, I was kinda bored driving through town heading home after school. I was doing around 35mph in 3rd gear, decided I would try to get it into 4th. Pulled it out of third, let off the throttle, held the shifter with a little pressure over where it slides into 4th gear, then all the sudden it just slipped in and away I went. I think just as long as you dont get any grinding you should be good right? I havnt done it in a couple weeks...
