What a $100,000 Will Get Ya
Knuckledragger
Payson, AZ
Way too many 000's. You could probably build one from scratch for that much scratch.
boosted power
Troutdale, OR
That's a lot of $$$, but they are probably selling it for a loss.
Obviously a frame-off resto like that is damn expensive when you are paying a shop by the hour.
rjjp
Needs to go test
Clare, Mi
HAHA.
Ravelco anti-theft device A removable 16 pin male plug (which when not in use connects to your key chain) makes all the electronic connections. A hidden armored steel cable protects the wires from the rear of the RAVELCO base on through to the engine compartment where all the connections are made and camouflaged. When the plug is removed from the RAVELCO, it is impossible to start the vehicle. There are more than 100,000 different combinations. NO MASTER PLUGS. An impossible obstacle for even the most persistent thief. No Bells or Whistles . . . Just Results!
First off with 16 pins it's over 20,000,000,000,000.
Secondly the only reason it would buy you more that 30 seconds is because they put a computerized SB Ford in it.
So technically it wasn't a restoration, it was a resto-mod.
ON EDIT:
And they did a good job of hiding the splices, I already found 2 of them from my side of the monitor.
Goofyexponent
Mentally Unstable..
Halifax / Nova Scotia
"•New fuel injected 347 engine producing over 400hp with 250hp/275tq to the wheels"
That's a LOT of parasitic loss through the drivetrain me thinks....
truckonfire
