crash-harris
Breaker! Breaker!
Cruise control finally works! ...kinda.
On the way back from our Memorial Day work weekend at our favorite campsite, I decided to attempt to use the cruise control again. This time it worked! BUT! The Set/Accel switch is functioning as the resume switch and the Off and Coast switches are both functioning as set/accel. The Resume switch does nothing. The only way to turn it off is to tap the brakes and I'm not 100% sure the On button is actually turning it on. I also noticed that my horn stopped working which previously was due to only 2 lag bolts connecting the column to the firewall and not grounding well.
I did save the link to the cruise control diagnostic info, but wanted to get opinions first. Ideas?
