Water separator?
Cubey
Van dweller
USA
Was that the only filter on it? Just curious because the brown lettering shows that it is a 2 micron filter, which is small for a primary filter on a 2 filter setup.
I can't remember for sure whether or not it had the main fuel filter, but I think it did. I didn't take any pics if it. Maybe they had a really nasty tank and seriously wanted to protect the lift pump.
u2slow
bilge rat
Coastal BC
The bowl is where water collects due to gravity. Heat is often applied to help the separation.
Primary is typically a coarse filter (i.e. 30 mircon) w/water separator. It should get rid of most contaminants. Secondary is a finer media. You have pump pressure working for you in getting the last bit of crap out, and it protects your injection pump in case the lift pump scatters.
Ghuds
Colorado
Thanks everyone for your replies. I’m having trouble with my email so it’s taking a couple days to get back. I’ll see what I can figure out. I appreciate it!
tke395
