mbolton1990
Is the spacer supposed to be on top of the pulley or underneath it?
Common sense is telling me it's supposed to be underneath it, with this new Gates pump it won't let me install it with it on top ,the bolts keep rubbing against the pulley... but that's not how I took it apart.
If you can't tell I'm having to undo ALOT of bad mechanic work on this van, if you look at the top left bolt for the WP, you'll notice the bolt has no washer. Isn't that enough to potentially damage the engine / IP? I know the clearance's are super tight,oh and the top and bottom bolts had no RTV put on when they did the old WP install so of course those bolt's leaked..
Man, doing this work further instills in me one of the sayings of my old man " If you want it done right,do it yourself"
