Water leaks from OBS heater case after heavy rain; Evap drain plugged?
mccall52
Woodstock, GA
Hello,
Is anyone aware of an evaporator drain that can get plugged? After heavy rain, there is a stream of water that comes down into the passenger side floorboard, directly from between the firewall and the heater case.
I was able to duplicate it by also hosing down the cowl area through the perforated area near the wipers. Not so much just the base of the windshield, so I'm not suspecting a seal failure between the glass and the cab, at least not now.
I appreciate your help.
Clb
Another old truck
nannyfornia
Fwiw
On my ole brick.. The hood seal was gone, someone replaced the heater core and left the firewall seal out !
Outcome,,, wet pass floor board!
Hope this helps, aint gone into my 93 yet(38k on the clock)!
Good luck cb
mccall52
Woodstock, GA
I forgot to mention my blower only works on high, I've been meaning to replace the resistor pack. The water could have taken it out now that I think of it I'll pull the blower motor at the same time to get a visual on where the water is coming in and how it is exiting.
m2rtin
