had a small incident this morning going to work, about 5 degrees this am truck fired up ok, about 6 miles from home fuel filter light flashes, i let off the go pedal and it went out. gave it more fuel and it came back on about a 1/2 mile later it dies. i pulled off the hiway and let it set for a few minutes,activated the electric fuel pump and checked the scharder valve, got some fuel so i cranked it and it fired up finished my trip and drained the fuel filter which is only two weeks old.
my questions, how much water does it take to stop the fuel flow to injector pump and what do you guys use to get rid of water? by the way i use power servce every tank usually double dose
thanks, gunnie
thanks, gunnie
