JeffMoss1
Jeff
Alright...if I die before I'm 100 years old, it'll be curiosity that will have killed me.
Have any of you WVO guys ever tried burning waste motor oil as a fuel? I have a heated tank and a heated fuel line system and I decided to give it a try.
I'm in the process of rebuilding a 6.9 engine to stick into my van, so I decided to make my current motor (that was still running quite well) into an experiment. I put a whole bunch of waste motor oil through my filtering system, just like the wvo I use, and then drove on it (heated.)
It seemed to work fine, just like the wvo. Burned probably like 30 gallons of it. Shortly after, I had a charging problem (voltage regulator/alternator). Whichever the problem was, I replaced both, and the batteries charge again, but all of a sudden, I'm having issues starting up.
One might say it obviously was a result of something I just did with the batteries/alternator/charging system, but I can't think of what it could be. The engine seems to have good RPMs when turning over, but it sounds like there isn't enough fuel getting into the cylinders right away or something. It cranks fast for 10-15 seconds, struggles a bit, then finally roars to life.
The only thing I can think of is that I made belts to tight or something and it's putting a bigger load on the starter to turn the engine over.
When driving, i've noticed a buzzing sound with the engine (buzzing gets louder with throttle.) I have no idea what's making the buzzing sound. Also fuel mileage is getting slightly worse (with diesel.) Lastly, I noticed that the fuel filter mounting bracket also came loose (the nut is nowhere to be found.) I haven't fixed that yet either. I wonder if that's causing anything.
I looked around for air leaks in the fuel lines and couldn't find anything. Engine doesn't squeal at all.
Anyway...thoughts?
Anyway...thoughts?
