Wanted - 460 engine brackets - Will trade IDI brackets
Iowa 73
FNM
IA
Just checking to see if anyone out there is going the other way and would like to trade.
I have pulled a 7.3, and am going back with a 460. Need the engine brackets that bolt to the crossmember.
Let me know if you have anything. Thanks
idiabuse
Princeton Fl
Yea I have a new set of solid mounts for the 460 I purchased but never used. Just have to find them.
Javier
Iowa 73
FNM
IA
Sold the IDI frame brackets. Still looking for 460 frame brackets if anyone has them.
idiabuse
Princeton Fl
Found them, solid mounts that bolt to a 460 and drop it in. is that what you need?
Javier
Iowa 73
FNM
IA
I need the frame brackets that are bolted to the crossmember. These are what the motor mounts bolt to. I have motor mounts already, thanks.
Iowa 73
FNM
IA
Buying a complete truck to part out, so I no longer need these. If anyone needs a set of IDI brackets I will still trade a set for a spare set of 460 brackets.
Thanks.
Iowa 73
FNM
IA
Ok sound good do you use PayPal and will they fit a 92 it's got a 351 now but will be a idi soon
I do take Paypal. I have a 93 frame that had a 351, so I will check this weekend and confirm that they fit.
Iowa 73
FNM
IA
Looks like the 5.8 crossmember is different on the drivers side. The passenger side is the same. I think swapping an IDI in will take some work. You will probably still need some brackets to start with.
MadScientist
