ok well i think i have a dana 60 coming from a dual wheel dump truck.if i was to get the shackle reversal kit would that make life easier as it appears all i need from a 4wd truck would be the rear shackle mounts and the asociated steering linkages and panhard bar.
ok well i got my D60.and the best part is all i gotta do to get it and all the associated parts to go with it is........................yank the tranny out of it for the guy thats good and bad as i need the extension housing and the output shaft for mine but he may have a junk E4OD that i can have to **** those parts from so will the RSK make life easier or what?im gonna lop the frame off behind the front cab mounts so ill be able to get all the measurements and brackets that i need.and the best part is its comeing out of a dually dump truck!!
