Voltage drop in cab with load (blower motor)
daazedjmcfarland
Enumclaw, WA
I have noticed the same on an 84. It's mostly just old wire and old connections. Definitely running some 8 gauge would help and cleaning up those fuse box connections. But, the biggest thing you can do is put the 3g alternator in there and re run some 1/0 grounds and hot wire. I had to do this because of the speaker system I put in and I was worried about the draw from the electric lifter. It is actually way easier than you might think it is. Hardest part was getting the damn pulley off of the old alt
Sent from my SM-G900T using Tapatalk
FORDF250HDXLT
Maine & Oklahoma
voltage drop in the cab with the heater blower on
maybe there are better options
summarized with everything you need to focus on.:D
the 3g upgrade is one of the first things i would do to a pre '92.5 idi engine before she hit the street fwiw.
typ4
Newberg,OR
Blower relays to take the load off the dash. Did both trucks. Huge difference
CDX825
filtration nut
Litchfield,Ohio
From what I recall power is fed to the blower motor. Then the ground side of the motor runs to the resistor block and the actual blower switch grounds the different taps of the resistor to adjust the speeds.
If this is the case you could easily use three relays for each speed and reverse the way power flows from factory starting with the relays. The relays would all be fed ignition switch power to one side of the coil. the other side would be grounded by the switch. Power feeds in to the relays then out to the resistor block for each speed. High doesn't use the resistor so its just straight to the motor. Then the motor has a constant ground instead of being switched.
That's the way I want to do mine so none of the load is on the dash side including the ground. So the dash switch is only has to carry the load of the relay coil.
daazedjmcfarland
Enumclaw, WA
I know this may be off topic but could you wire a dimmer switch for the fan control?
typ4
Newberg,OR
I use 4 relays, power, low,med,high. At least do 2, power and high, it puts the most current through blower switch. No on the dimmer.
bbjordan
Snow Monkey
Ashern Manitoba
Check your blower motor to see that it turns freely. On my '91 I had to lube up the bearings. I used ATF.
daazedjmcfarland
Enumclaw, WA
They aren't really meant for blower motors but I build PCs and they give you speed control on the fans....you'd just need a 20a or 30a one...not sure what kind of draw these blower motors have
BDCarrillo
Abilene TX
Should be easy with a potentiometer and 555 timer running a big transistor. That'd also be a good way to divorce the motor and dash wiring.
Great, another side project lol...
FORDF250HDXLT
Maine & Oklahoma
^ i would suspect this too.perhaps it's just bad.im all for taking the load off a switch and putting it on a relay.even if it's just for high speed.however the load it's pulling,is the load it's pulling.with a 3g alt, a blower motor shouldn't mean a thing,let along a noticeable voltage drop.
ifrythings
BC
The thing that everyone is missing is the fact that almost everything in the cab is ran off of one power wire through ONE pin on the firewall plug, the exact same pins used on the glow plug harness that likes to melt. They changes this on the 92 and up trucks but if you really want to see a difference run a big 8,6 or 4 awg wire from your starter relay right to the yellow wires on the ignition switch and you'll see a difference.
For reference, large yellow wire runs almost everything in the cab
Black/orange runs the lights and a few other smaller things
Small yellow wire goes the the brakes and hazard lights
Those are the main power wires into the cab upto 1991 (maybe different a bit for 80-86)
Only thing left after that is to relay the ignition switch.
Edit: to add to this, the ground system in the cab isn't done the best, ford grounded everything to the metal dash frame which is then bolted to captive nuts on the a pillar which is still nicely painted, grounding the dash to a nice solid clean ground will help also.
ifrythings
BC
Not 100 percent sure on the 80-86 but if they are the same like 87-91 then it will be up around the ebrake release lever.
