Videos of the puller
CoalMiner
Gretna/NE
What kind of boost are you running right now? And how much do you plan on pushing with a smaller turbo? If it's 20 or under, the HX35 will be better, but that's still on the low side of the map for that charger. HX35's are a common turbo to use on tuner cars, but they are out of the map at low pressure ratios.
Look into an S200 or S300 based charger that the tuner guys use. With a strong map up to 22 psi. Something that was used on a high winding, 600+ hp V6 will supply plenty of air for a 4500 rpm IDI. If you're worried about restriction, you can always get a decent T3/T4 turbine housing on the S300 frame, instead of a smaller housing used on the tiny motors.
-yeah the garret we have is a t4 flange. we are just gonna kick around the idea of a hx casue we dont have a s200 or 300 laying around or the budget. mind you that we have two 6.9's and a 6.0 liter that are in the process of building.
We have only got 6-7 pounds of boost. our exhaust is tight and there is alot of rpm and fuel. it doesnt help that the exhaust housing is really large. i think if we had something smaller we could have better luck in lighting it.
and that truck has seen alot of torch work. We stacked 1200lbs on the truck and were still about 300 shy of 7500.
dyoung14
Is getting worn out
spencer,tn
well sounds like the turbo is a little to big and its having trouble spooling it. a psd turbo would probly work perfect
CoalMiner
Gretna/NE
what year of powerstroke? like the obs style or newer?
hesutton
The Anti-Anderson
Bowling Green, KY
Coal Miner.... How about putting your mods in your sig so we know what you having so much fun with.
Dude, I love seeing these IDI in the mix at pulls. Cummins after cummins with a few Dmax's through in gets really boring after a while.
KEEP IT UP!:hail;Sweet
Heath
dyoung14
Is getting worn out
spencer,tn
probly the best one would be the 99-03 psd turbo, its wastegated has a .84a/r exhuast housing and 1.00 intake housing, so it should spool fairly quick and make great boost and mov e lots of air, the older non gated one off the pbs psd is non gated and has a 1.15 exhuast housing and a 1.10 intake housing but its a samller turbo overall so it would be fit into more space limited areas
kas83
Plover, WI
But then you're talking surge city, and that's not what you want either. An HX35 will be a better alternative to these examples, get a 14cm gated, or 16 cm non-gated turbine housing and let it rip. Might even be able to get away with an 18.5 or 21cm H1C off an early 12 valve VE engine, given the extra displacment and rpm you have.
CoalMiner
Gretna/NE
I gotta ask What is "Smarty Programmed" about it?
hahahaha
well, there is about 7 of us that all pull together. four of us have dodges, one street modified gas chevy, and two fords counting the 6.9. We threw that sticker on that truck just to mess with people. The sticker was originally meant for my friends 09 6.7 dodge he got the smarty for.
dyoung14
Is getting worn out
spencer,tn
hahahaha
you are unable to recive pm, so i guess i will ask here, what all has been done to your ip besides shimming the governor? i have a spring in mine that allows me to pass 4000 easily highest i ever went was 4400 but im not sure really what my max is, but im curios as to what else you done to your pump if you dont mind sharing
CoalMiner
Gretna/NE
honestly we dont know. We took it off and Joel, a guy that farms for us, took it to his shop and did something to it and we just put it back on. We started it and there was mass amounts of fuel. I wish i knew what he did, he wont tell us what he did either. i wish i could help.
dyoung14
Is getting worn out
spencer,tn
hmmmm, what would he charge for another?
CoalMiner
Gretna/NE
you know, im not really sure. I know that i have to have another pump turned up and i can ask him to see what he says. we honestly never thought that the puller would get this kind of attention. lol
65sixbanger
New Braunfels, Texas
Why dont yall just put a banks or an ATS on there with an intercooler? You would have more boost and the air going in the intake would be cooler. The videos seem like the rpms never started turning high enough IMO.
kas83
Plover, WI
A Banks or an ATS will be more of a restriction than a help on that truck. Given the RPM and fuel, the thing would blow past 15 psi boost, and drive pressures would be through the roof. Those turbos would be so far out of the map that even with an intercooler and even nitrous/water **** the charge air temps would skyrocket also. A non-typical turbo is needed for this non-typical application.
funnyman06
Coventry, RI
You guys should really dyno this truck. I bet we would all be interested in what kinda numbers it puts down.
placidoert
