valve train noise.
jactoy4x4
Eugene
So pulled the covers off and everything "appears" to be fine.
You cannot hear the tick at idle, but as soon as you bring it up it starts gettin noisy. Makes no noises on or off the throttle like a rod bearing would make...which kind of puzzles me. The noise seems to be coming from either the back passenger cylinder or the one directly in front of that.
Makes no difference in noise when i swapped an injector out. Still there. Possibly a collapsed lifter?
Here is the weird part. It never EVER has done this before even on a cold cold start. You pop the throttle quick and let off completely....and it shudders and dies.:confused:
However it will sit there and idle just fine, starts fine, still with that nice "chuffing" outta the stack.
So if any of you guys have any other suggestions....I am humbly lost and stumped!:dunno
jtate
houma,La
how about breaking each injector line while its running to see if you can narrow it down to which cylender. i also narrowed a bad injector down using a heat gun by shooting the exhaust manifold to see what the temps were by each port. just throwing that out there.
typ4
Newberg,OR
were any of the valve springs blackened, like a really bad exhaust guide? You may have a burned exhaust valve, unlikely bot you never know, lifters dont usually collapse but it can happen, were all the rockers moving about the same amount?
jactoy4x4
Eugene
I did crack each injector line. Each one i cracked spit fuel and made a definite miss in the engine. Which is why i am so puzzled.
jactoy4x4
Eugene
They were all about the same color. I did not run the engine with the covers removed. Didnt want oil all over the driveway.
HammerDown
Glenolden Pa
I had mine off and running in the driveway...not a issue.
also listened to each one w/a long screwdriver pressed to my ear, also checked to make sure oil was pumping from the pushrod and to verify all rockers were lifting the same amount.
jactoy4x4
Eugene
i picked up a complete running 7.3 tonight for the too good to be true price of 200 bucks! had to go pull it. took us about an hour. got engine, starter, alternator, and an extra IP. (i now have 4):sly
tomorrow ill be pulling my engine and getting this one cleaned up and a few new gaskets in her then ready to go in. ;Sweet
Bo17
