hadley000
I was using 1 quart every 6-800 miles before changing out my CDR. There was a noticeable oil film in the intake before the change out, but now it's gone. Now I burn about 1/2 quart every 1500 miles. There aren't any leaks other than the wet passenger manifold from a valve cover gasket I've yet to replace (driver side already done), but it doesn't drip so can't be leaking much. Is this typical? Do these engines use a bit of oil in normal operation?
