Dirtleg
The electric pump might change this procedure but when I changed my IP I left all of my injector lines slightly loose at the injectors and then cranked the engine in short bursts (15 seconds cranking 2 minutes in between) until I had fuel at all the injectors to bleed the system. Then I tighened them up and it started right up.
It seems to me that if the pump were full of air it would collect at the top where the fuel return line attaches. Perhaps you just need to run the electric pump longer.
