Dirtleg
Well I very carefully, I thought, measured everything and double and triple checked every last detail about the new bushings and the shaft for fiment. All my specs were within what was expressed by Russ (type4) and so I went ahead and reassembled the turbo. I installed the new compressor wheel and then put the housing on. No discernable end play, that's good. Very little side to side movement, much less than the turbo on my car for example, but guess what? The new compressor wheel will touch the compressor housing when pushed to one side. It is a really tight fit. Spins freely and no wobble but that doesn't change the fact that the compressor wheel can touch the housing.
EDIT: I noticed that it seems one side of the compressor housing is closer to the compressor wheel ie... it's off center. I guess I'll have to have a crack at centering it before I freak out. This is also the only spot the wheel can touch. But man it's still a super close fit. Too close IMO. Perhaps I should hone the compressor housing out a little. But as said before there really isn't much play in the shaft/bushings.
I am aware that oil helps center these things but I am not confident that it will make this thing safe to run.
Now what?
Now what?
