Truck shimmy's when take off
93fordturbo
La Crosse, Wi
I can drive a manual pretty good, and i normally take off in second. But when i do so, or even take off in first, the truck kinda shimmy's or jolts or shakes when i take off and dont have the clutch out fully. Once clutch is fully let out, it goes away. I have drove other manuals where i feather the clutch while taking off, and it doesn't shimmy like this. Bad clutch? Bad tranny?
biggin92
Yeeeee Haaawwww
umatilla fl
probably has a solid flywheel in it,that is one of the side effects, the dual masses dont do that often
87crewdually
Southern Nj.
Agree with biggin. Your feeling the slipping of the disk and the flywheel is solid so it's not dampening it like a dual mass.
biggin92
Yeeeee Haaawwww
umatilla fl
I personally like the dual mass as long as it is on good shape , there is less noise and less stress on the tranny , however the solid flywheel is cheaper and they also do the job.
