If you can't find any leaks in the fuel system, put an electric fuel pump inline, and that will clear up funky starts. But like the others said, you got an air leak somewhere...most likely your return lines.
If you get serious about an electric pump, make sure to take out the factory lift pump and use a BBC fuel pump block-off plate. Lack of fuel/lubrication to the factory lift pump will cause it to eventually fail, and probably toss broken parts into the oil pan.
