cowboytueller
Hey guys I am getting a temp gauge for my E4OD and I was looking for suggestions on where to put the probe. Also what is a good temp for the transmission and when is it overheating. Thanks
Where can I find that pan? Autozone?
Autozone? Not a chance for the one in my picture. That's a genuine Ford part. It has "Ford" stamped on it, in an oval. You'll find it at your local friendly Ford dealer. In other words, go to your local friendly robber baron. Take your vaseline with you.
From a post 8 years ago (this was my source for the part numbers):
[FONT="]If you should want the deep oil pan for your E4OD with the drain plug and the reusable gasket, here is the part number for the kit, includes pan, gasket and bolts necessary to do the conversion:
F7TZ-7A194-DA
The pan itself, for the later E4ODs, is a
F81Z-7A194-BA
Hope this helps you.
[/FONT]
