Trans Issues
Worstenemy453
King George, Va
My buddy has a 4x4 CCLB PSD. Its a 97. He has the e4od and its causing hella problems. How hard would a 4R100 swap be. I heard they are the same case with just different sensors.
Double-S-Diesel
parts seller
derry pa
same trans , just some different internals, in place of the e40d, just dont plug in the sensors, I also believe the selonoid pack is different
trackspeeder
Stone crusher.
North Branford. CT
It will bolt up with no problem. Ignore the two sensors on the top. You might have to change out the Transmission Range Sensor. (MLPS)
