Tranny Question
Fordiesel250
Iowa Park Texas
I have a 2001 F250 with the 4r100 transmission. When pulling my fiver and then backing up tranny fluid strarts coming out. What do I need to do to fix this problem. I just had the fluid and filter changed.
trackspeeder
Stone crusher.
North Branford. CT
The pump seal is getting soft with the tranny heat. This is common with the gray pump seal. Replace it with a Viton seal Precision #16601EV. You can get it at Napa.
While your at it change out the tranny cooler too. Use the cooler from a V10 or better 6.0. (5R110 cooler)
