tranny jack and removal help please
HankHill
NY
I'm picking up my parts truck this weekend and want to throw my zf in asap before snow flies, I would just like to make sure I have this down on the removal process for both e4od and zf5
remove driveshafts
take out bellhousing bolts (how many 4??)
put tranny jack on trans
unbolt trans mount and xmember then lower
I'm not sure on the torque converter is it bolted to the flywheel or is it attached to that spindle in the front of the tranny?
what are your opinions on this tranny jack from harbor freight http://www.harborfreight.com/floor-jack-transmission-adapter-39152.html
THECACKLER
Da Central U.P.
6 Bell Housing Bolts - two on each side and two at the top.
Torque converter bolts to the Flywheel / Flex plate - rotate engine to get to them.
The HF tranny jack is a sloppy POS but it can be made to work. I know first hand...Be careful of it tipping or the tranny trying to roll off onto you or worse onto the concrete and breaking. Maybe look into renting a T-Jack. You might also need it to raise the flywheel into position when you mount it since there is no index or dowel pins to hang it on. On some slushbox setups there is an adapter on the back end of the crank that the flex plate sandwiches into place that you will have to pull off before you heft the FW into place. Make sure you use the bolts from the FW not the flex plate or at least compare the length. Also don't forget to use sealant on those flywheel bolts since they go through the crank flange and into the crank case.
Diesel_brad
Dunce
gilbert pa
remove driveshafts
1 battery
2 drive shafts
3 t-case
4 put jack in place.
5 torque converter nuts
6 trans cross member
7 bell housing bolts(6)
8 trans
start
MR.T
PNW
Here's some pics from last time I had mine out. Note the custom rubber hoody over the top bell housing vents. Keeps the water and potential fuel leaks from dripping above the clutch -- but still allows plenty of air circulation.
Regarding tranny jacks, get the best one you can afford. If you have a transfer case attached, make an out-rigger from some angle iron and move the left caster outboard about 6 inches (see pic). I used an extra strap to hold it on. Some rubber gasket material and some thin wood blocks make it sit better in the floor plate of the jack.
The rear is much higher then the front to make the crankshaft parallel to the concrete floor. This makes it easier to line up the pilot bearing and push the tranny home.
HankHill
NY
thanks so much you guys, these posts and pictures have helped me alot, I have alot more cut out for me and alot more to learn than I thought.
while I have the transmission out, what bearing do I replace and where do they go, only two I have in my mind is pilot and clutch throwout bearing but have no idea where or what they do.
About the crank bolts... They are not the same from the E4OD flexplate. So you will need the correct bolts for the standard flywheel setup. Just one more thing... Between the flexplate and the crank you will find a spacer thats around 1 1/8th inch thick. That needs to be removed and saved. Ford no longer makes them or any trans shops but.... Brians Truck Shop in Leadhill Arkansas can fab one up for you if you lost yours during a trans job. I know someone that lost a valve cover when they took apart there motor....:eek::rotflmao:sly Lifting from the back is far easier than lifting from the front. The motor is almost exactly lined up for the trans. I lifted from the front and it was hell. No matter what I did it was wrong. When I finally got the truck frame highe enough for the trans sitting on the jack to slip under the truck the motor was too high. I had to drop the truck so the trans would match up. BTR installs trans from the rear lift just like we should do. Laying on our backs. Also support the motor from the oil pan rail only. Not from the bottom or you will dent the pan into the oil pickup screen. That will kill the motor. Jack up the motor from one side of the oil pan rail. Then place a cut 2x4 from the ground up to the other pan rail. drop the jack and its set... It can't fall off either just as long as the truck does not roll away.
jukess289
powhatan va
are you swapping a E4OD for the zf 5 speed if so I just did it on my 94 350 4x4 not too bad but the zf trans is 5-1/4 inches shorter and will require longer rear shaft shorter front shaft and the floor shifter for the 4x4 needs to be shortened
HankHill
NY
yes I am doing a e4od to zf5 swap, I have an entire parts truck aswell.
icanfixall are you saying I need to lift the motor to get the tranny or lift the frame for jack clearance?
do I put that spacer back in when I put the flywheel on
You need to have around 26 inches of clearance for the trans and jack to fit under the truck. Thats what my E4OD required. The E4OD crand shaft spacer will not be needed with the standard trans setup but. You should save this part for someone else. They are needed when you convert from the early heavy cast iron flexplate and the newer stamped steel flexplates. They are worth as much as you want for them.. Kinda like gold...:sly No... The motor just needs to be held up so the weight isn't twisting the motor mounts. Not supporting the motor will ruin the mounts. Place the new trans on the jack and measure how much clearance you need. Thats the best way to know if you need more lift. Usually the frame rail is the low spot on our trucks.
HankHill
NY
ok, thanks for extra info fellas, now another question.
I have never replaced a clutch before, so please give me as much detail on this as you like. I will start with my basic knowledge
put in new pilot bushing/bearing
attach flywheel to crank
bolt clutch to the flywheel
put the pressure plate on the back of clutch
and thats all I know. And what does the clutch alignment tool do?
nyteshades
Tulsa, OK/Ashland, WI
The clutch alignment tool gets the splines lined up between the flywheel, pressure plate, and clutch disc. This way everything is lined up when you put the transmission in. The input shaft has to go through all of those holes so the transmission will bolt to the block. Trust me, it's no fun to do it without one.
Here's a tip. When you're trying to get the input shaft started in the holes.....it helps to turn the output shaft to get the splines lined up.
MR.T
PNW
Hank: This is something I wrote up a while back thinking it could possibly be a tech article. It might have some of what you are looking for. Note that Icanfixall's method of supporting the engine is probably better, but the goal of not denting the bottom of the oil pan is the same.
Here's a few notes on clutch replacement surgery that might be helpful. The patient is a 1988 F350 4x4. This is going to be a SMF (single mass flywheel) conversion using a LUK LFW127 flywheel and a LUK 07-131 pressure plate and disc.
Having done this before, it will not have a gear roll-over noise issue, essentially no sound difference with the clutch in or out while in neutral. The reason for pointing this out is that some SMF clutch discs make a lot of noise, one in particular I tried made gear noise louder then the engine. I believe it's all in how the springs are designed.
Here's how I do it:
Wash the underside of the truck first, then remove the negative terminals on both batteries before beginning.
Block the front wheels and jack up the rear end as high as you can go, then put it on jack stands. As you can see in the pic, ramps were slid under the tires for additional safety. Deflate the front tires to about 20 PSI. The point of this is two-fold. The engine and transmission normally slant down at the rear and this will tend to make the crankshaft as parallel to the floor as possible. This makes moving the transmission jack to align the input shaft with the pilot bearing easier. Also, you'll be able to slide the tranny out from under the rear of truck with the extra clearance height.
Shift the tranny into 4th gear and the xfer case in 4W-HI. This will help later because turning the Xfer case input shaft will rotate the tranny input shaft for spline alignment.
Remove the gear shift and 4x4 shifter -- each has two blots, then remove the rubber boots.
Remove the front seat and floor mats.
Remove the transmission sheet metal cover, then remove the top-shifter from the transmission (4 bolts). Duct-tape over the opening to keep dirt out.
Remove the front and rear drive shafts.
Remove the nuts holding the exhaust piping from the exhaust manifolds. Let the exhaust hang down a couple inches so you can remove the clutch inspection cover (4 bolts).
Remove the skid plate under the xfer case.
Because the clutch can be used to jack the crankshaft against the thrust bearing, check the as-found runout on the flywheel now. Mount a dial indicator with a mag-base, dial on the face of the flywheel. Rotate the engine with a 15/16 socket on the engine front vibration dampener, then push in the clutch momentarily to seat the crank against the thrust bearing. Max spec is 0.010 TIR (total indicator reading), <0.005 is nice. If it's out of spec, checking the flywheel itself on a flat surface plate or equivalent will determine whether the problem is the flywheel or the mounting surface on the crankshaft.
Now is a good time to check the travel of the hydraulic slave rod, the nominal travel is 13.5 mm (0.53 inches). If travel is low, the clutch may not disengage fully. Firewall flexing, low fluid, and air in the system are typical causes. The slave on mine has a set screw to bleed the cylinder, but I believe some do not.
Remove the hydraulic clutch slave cylinder, leave the hydraulic line attached. Assuming the plastic retaining tabs are intact, push on the clutch fork to force the slave cylinder piston rod into the cylinder and attach the plastic tabs. Use a screw driver to bend the metal retainers away from the bell housing a bit, and take the cylinder off at an angle that leaves the rod in the clutch fork until the cylinder clears the bell housing. Rotate the slave cylinder 180 degrees on it's hydraulic line, then tuck it away behind a convenient brake line to get it out of the way. NOTE: Attaching the clutch slave cylinder is similarly awkward, place the plastic cup with the rod into the fork at an angle, then push it onto the bell housing until the metal clips snap over the mount, then push on the clutch fork to force the slave cylinder piston rod into the cylinder to un-attach the plastic tabs.
Disconnect the electrical connections on the tranny and xfer case.
Remove the speedo gear/cable from the transmission. Bag the speedo gear and plug the hole to keep dirt out.
Place the transmission jack as rearward as possible without hitting the crossmember. It will be tail heavy with the xfer case on, so chain and strap it on the forward side of the top-shifter mount.
Safety note: The tranny and xfer case weigh a lot, and can crush you. The xfer case moves the center of gravity to the left, and to compensate, the left caster wheel on the pictured jack is moved further outboard. Some mechanics will separate the two components, it all depends on what type of jack you have and their weight capacities. In any case, strap and chain it securely to the transmission jack with some wood cribbing between the transmission and the floor of the jack to keep it from rotating.
Remove the two nuts holding the transmission mount to the cross brace, raise the jack until the mount lifts off the cross brace, then remove it.
Lower the transmission jack until you can get a socket on the top two bolts holding the bell housing to the engine.
Place a hydraulic bottle jack under the rear most part of the engine oil pan to support the engine after transmission separation. A piece of thick rubber gasket material between the bottle jack and the pan works nice to spread the load. Raise the bottle jack so it just lifts the engine slightly, and is supporting it. This should be a good bottle jack that you know doesn't leak down because it's going to be here until re-assembly.
Remove the 6 bolts holding the bell housing to the engine - the 2 on the top are shorter.
Gently slide the transmission jack to the rear, and when the input shaft clears the clutch, lower it down.
Remove the 6 bolts holding the pressure plate to the flywheel evenly -- leave a top one for the last one removed and be prepared for gravity. Remove the pressure plate and disc.
Remove the 9 bolts holding the flywheel to the crankshaft -- leave a top one in for the last one removed and be prepared for gravity. Remove the flywheel.
Check for rear main and transmission input seal leaks.
Clean the bolt holes in the crankshaft -- they are through holes, so don't blow out the holes. Suggest using and old bolt with a couple of flutes ground in using a bench grinder.
Remove the clutch fork and release bearing. Always use a new release bearing, and consider a new clutch fork if it's worn.
In one of the pics you'll notice a custom rubber shroud over the top air vents in the bell housing. It keeps the fuel, oil, coolant or whatever out. It's easy to make and it's attached with silicone gasket maker
Clean the mating surface for the flywheel to the crankshaft, remove any dings with a flat stone or similar. Any protrusions or dirt here will tend to cause the face of the flywheel to run-out, and the effect is magnified by the relatively large outside diameter of the flywheel compared to the diameter where it attaches to the crankshaft.
If the flywheel surface looks good and the runout was acceptable, I usually just clean up the surface with some wet/dry paper on a ground-flat sanding block. Otherwise, re-surfacing is advisable. Whatever method of re-surfacing is used, the end result should be that the face of the flywheel is parallel to the crankshaft mounting surface. To check this: Use a large flat surface with a good finish (surface plate, mill table, even a good drill press table). Grease up the mounting surface of the flywheel and place it on the flat surface. Place a dial indicator on the edge of the flywheel's friction surface and slowly turn the flywheel. I prefer less then 0.003 TIR in this test because it will probably be a bit more after mounting to the crankshaft (Murphy's law). There's more flatness checks that can be done with a surface plate or mill table, and if you have access to these you likely know what to do.
In the pic you'll see my son re-finishing this flywheel on a rotary table in a milling machine. After machining, it's block sanded to improve the finish a bit. The face run-out and all around flatness was 0.001 using a surface plate and dial indicator.
Press a new pilot bearing into the flywheel. I used the standard roller bearing style, there is a plastic/kevlar style available as well.
Clean and check the mounting surfaces of the bell housing and engine plate. Any protrusions or gunk on these surfaces will effect the pilot bearing and input shaft alignment.
Mount the flywheel to the crankshaft, don't forget the 10-hole washer plate and adding sealer to the threads if the bolts are not already pre-coated. The torque is 50 FT-LBS.
Right now is a good time to check the flywheel face runout, except that the crankshaft needs to be forced against it's thrust bearing with a prybar before each dial indicator reading. Because the flywheel has been checked on a flat surface plate and the mounting surfaces are cleaned up, I usually just wait and do a final check when it's easier to use the clutch slave cylinder to jack the crankshaft against the thrust (same as before).
The surface of the input shaft tube where the release bearing slides may need some touch up with some wet/dry paper for a good finish. Also inspect the end of the input shaft that goes into the pilot bearing and polish as necessary.
Apply a very small mount of high temp grease to the transmission input splines, then slide the clutch disc on and off. Remove all the excess grease, repeat until there is no excess grease -- just a fine film.
Apply some high temp grease to the inside of the release bearing, the clutch fork pivot, and to where the fork contacts the back of the release bearing. Install the release bearing and clutch fork.
Install the pressure plate and clutch disc using the alignment tool to center everything. If the alignment tool fit is loose, compensate by lifting the disc slightly. The torque on the pressure plate bolts is 20 FT-LBS and I prefer blue locktite or similar on these.
Rotate the crankshaft so that the clutch disc splines are lined up vertical -- hang something on a string to act as a plumb-bob to sight against. Now rotate the tranny input shaft until it's splines are similarly vertical (sight against a rib in the bell housing). Note the position of the output shaft of the transfer case for reference. All this pre-positioning is going to take the guesswork out of whether the splines are aligned.
Install the transmission. From the bottom, sight up the bell housing, using the flywheel as a reference to get them parallel. Use a tape measure to keep the gap between the left and right sides of the bell housing and engine equal. To tell if the splines have mated, try to turn the xfer case output shaft.
At this point, assembly is essentially the reverse of disassembly, so there's no point of repeating the above.
Best of luck, hope this was helpful.
Here is how high the truck has to go to get the tranny out. You can even tip it a little to get a couple of extra inches. If you haven't jacked it up yet or started to remove the tranny, you can get the oil out by disconnecting the rear line going to the cooler, leave the hose on it and put it in a 5 gallon bucket have someone hold the hose or fasten it with a spring clothes line pin, start the engine and pump it out, most will come out, shut it off then. Won't hurt the tranny at all. That's how I change fluid in it.
Vinceslamer
