tps wire voltage
sms8921
Western, Pa
Yesterday I installed a new tps. The old one was causing my new Tranny to shift erratically. The voltage on the wires seem to be off from the write up I read on here. When plugged in the top wire (orange and white) I get .01 voltage. Middle is 1.19-3.85. And bottom black wire is 4.99. I thought the top wire was supposed to have 5 volts not the ground...
gandalf
Senior Member
Air Force
CA &/or Maine
You have the idea, but the wrong procedure. All measurements are taken on the middle wire. I'll paste in a write-up I saved long ago, from the previous board, which shall go un-named. I lifted this from a posting by CDNSARGUY, who in turn took it from Dieseldon.
[FONT=&quot]RGMS4x4 I think your ok as long as the engine idle was set to spec.
This is a post by DieselDon I have taken the liberty to trim slightly.......
Hook up the negative lead of the volt meter to the battery ground and the positiove lead to the center GY/W ( grey/white wire which is the FIPL signal wire), I use a paper clip up the side of the wire in the connector. The FIPL must be attached to the wiring harness. Engine low idle speed must be set to specs prior to adjusting the FIPL. Engine off key on........
With a warm engine, key on, engine off measure the voltage at the GY/W wire, if adjustment is required loosen either the bracket with bolts or just use the slack in the Torx screw holes. Now gently rotate the FIPL until you get some where between 1.05V and 1.1V. then tighten the torx screws or bolts which ever you loosened ensuring no movement of volt setting . Rotate the throttle lever to WOT see if you get 3.8 V but not more than 4.3 V.
The FIPL mounting bracket can be moved but ensure it is centered for a good rotation. Any adjustment should be made by only rotating the FIPL. If a new FIPL is required, check tang engagement as you take off the old FIPL and then make sure that the tangs in the new FIPL engage the throttle lever properly.
The closed throttle voltage: 1.1 V, .........wide open throttle voltage: minimum of 3.8 V but
not more than 4.3 V. [/FONT]
Middle wire key on but engine off. Have the engine warmed up so the fast idle and internal advance is off in the injection pukmp. I run at 1.2 volts closed throttle position. Can't really change the wide open throttle reading but to lesson the closed idle position. That can be as low as .96 volts but thats a very soft shift in the trans. Not what many want either.
JunkCowboy
