Tire size
scrappy
stock SRW rims will work fine with the 315's w/o the spacers. I know a guy that had 315's on a hemi @ stock height carrying a 1000 lb. snowplow. they will rub on the control arms even with the leveling spacers. What is the backspacing on the rims you are looking at, if it is not close to stock the 315's will rub on the fenderwells even with the lift
gotdiesel?
Fine Diner
New Hampshire
I decided to go with the Nitto Terra Grapplers (295/70/17), ordered them 2 weeks ago and they're backordered. should see them in 3-4 more weeks.
Jerry
Dunce
Alamana,Florida
I run BFG 315's on H-2 Rims with no lift and no problems or rubbing. And on this ranch it earns it's keep.
BMF
Texas
I've got Nitto 295 70 17's and skyjacker 2" lift coils with no rubbing. Most guys around here go with the spacers and 315's without any rubbing. I think the offset of the wheels has more to do with the tires rubbing on 315's.
Seven4eight
