timing aids
no mufflers
rhode island
i think this would mostly be for those in the rust area but could be helpful for all.
i wanted to check the timing on a 7.3 i have at the shop and i noticed the hole for the probe was very rusty. after some thinking i came up with something that worked very well for me.
here are the basic parts.
here is the problem. this is after the clean up.
this it the measurement of the probe, a 5/16 drill bit works great.
the modified bit and ratchet i used to clean the hole.
all i did was take a 3/8 nut, slide it onto the bit, weld it and cut the rest off. the 3/8 nut takes a 9/16 socket. its a slow process but does the job.
no mufflers
rhode island
more useful pictures.
will edit when my email loads.
EDITED.
Great hand tool made for a specific job. Every timing meter I rent out has a 5/16 drill bit and several other tools to simplify the timing of our engines.Just be careful working that tall probe hole. That has a crappy connection to the timing tab. The tube is just rolled over like a brass brad on a pair of pants.
dogdanblue
