mattplumber
Grab your fan and try moving the waterpump pulley up and down to check for play. All of the symptoms described sound to me like the waterpump bearing has assed out and the movement, however slight is causing the belt to slowly walk off. I've seen this before on my truck and others. Replaced belt and tensioner/pulley and still had it happen again.
X2 on maybe using an idler pulley off a gasser or maybe a powerstroke as I think they used a serp belt with more ribs which translates to a wider idler.......
I replaced all my stuff less than a month ago and the belt still rides on the edge of the idler pulley but the tension remains tight compared to the original worn out tensioner that I replaced which the little "ear" that holds the tail of the coilspring tight had broken and caused the belt to lose tension.
Check that water pump bearing-i'll bet thats where your problem is..........
And if you can pinpoint the radiator leak, it is repairable by an old school radiator shop if you can find one. We only have one left here in memphis and they repaired mine last week. I watched them do it and if you can solder/braze copper its a piece of cake. Use lots of good Marlin flux and mixed gas on the lightest flame setting..............
