Thought It Was Belt Drive, but YIKES!
idi_econoline
No Bed For Me!
Northern California
Hello, All.
A couple weeks ago, started hearing a metallic sound or slippy belt. Became more metallic. Just now, removed flywheel cover (E4OD) and checked convertor bolts. All good.
Then removed fan and clutch, then one belt at a time. No change, in fact it's getting louder!
Mighty scared over here.
Used to be able to load videos directly here. WTH?
Clb
Another old truck
nannyfornia
With a crappy speaker... Sounds like cracked sheetmetal, or a n errant fastener in the bellhousing....
idi_econoline
No Bed For Me!
Northern California
GOT IT!!!! Holeeeeeey........ No big deal..... just the starter solenoid hanging by its shaft!!!!!!!!! YIKES, again!
Both mounting bolts are gone. Starts just fine, of course!!
The metallic sound is the housing for the solenoid.... sheetmetal!
:mad::eek::oops:o_O:bail
Thanks for your attention, gentlemen! :Thumbs Up When in doubt , get back under there and touch EVERYTHING!!!!!! :yell:
Time to disconnect those batteries, eh?
idi_econoline
No Bed For Me!
Northern California
You checked the converter bolts, but did you check the flywheel itself?
Shook the flexplate. Next step would have been dropping the transmission to check flywheel bolts. It really is a sheetmetal sound, so flexplate was all I could think of!
Leroy
nashville
Glad you found it!
Sounded like something rubbing the fan to me, but knew it had to be something else, wiggling stuf is magic.
Clb
Another old truck
nannyfornia
Two words that I swear by from back in the days of riding Triumphs....
lock tite!
Glad ya found it before it grenaded!
JU57US
