My 94 likes to billow out greyish/blueish smoke (best color I can come up with, very color blind) It only really does it when you coast over long distances (i.e. coming down a long pass) and it comes out in puff roughly 3-4 seconds long, then 3-4 seconds off, etc.... As soon as you even tap the throttle the smoke screen goes away. I'm fairly confident I don't have air leaks anywhere. It did this with my old turbo, and the new turbo so I think I can rule out a turbo related issue. I also have a Road Draft tube so it's not blow by.
I've read a good way to test a bad injector is excessive heat on the injector body as compared to the other injectors. Is this best tested after a hard pull then quickly check @ idle, or can it be checked and identified on a warm engine at idle? To test w/ this method would one of those laser temp gauges be the way to go?
Edit: Forgot to add that it does this on either WMO Blends or Diesel. I have an electric fuel pump regulated down to a consistent 7psi. Usually I have a nice idle, on rare occasion my idle is a "lil" bumpy, but not atrocious.
