Thinking about goin to a dually
Yes front axle will be changed and it'll either have a dually bed or a flatbed but I haul a lot of hay and pine and cedar post so I can use my truck for it instead of dads or my other flatbed which isn't licensed and needs work.plus I want a dually lol
Sent from my Iphone using Tapatalk
I take it you plan to swap a D60 in then correct...not just toss dually hubs onto the 50?
Correct I've got the d60 with dually hubs already.
I hope you have the correct springs and pitman arm too...makes a difference.
So far sounds like bang up idea....
How wide a deck you want?
I like decks cause you can side load...stake pockets make it as good or better n pu box.
Maybe consider a tipper deck and hoist...then bam...yer unloaded!
Could always build it for a tipper...add hoist when $$$ allows
83ford
ford diesel baby
calico rock.arkansas.us
Yup got the correct springs all I like is a pitman arm and the drag link and a front drive shaft and probably as wide as a normal dually bed or just a hair narrower.idk about makin a tipper but I plan on being a welder after school so a flatbed will be perfect
fsmyth
conroe, tx
This is what mine looks like (it's kinda rough, but that's how I got it):
The tool box is sitting in the space for a welder.
Might give you some ideas, anyway.
83ford
ford diesel baby
I thought about a welding bed but a normal flatbed is better suited for me
that's my flatbed right now but it's only 2wd so it not as versital as what mine would be as a flatbed but mine won't have the load capacity either but bein as how I have another pickup I don't really need another one just to run around in. I can make this one to where I can actually work it
fsmyth
conroe, tx
Just so you know - there is not but about 1500 pounds difference in
carrying capacity between SRW and DRW with Load "E" range tires.
But I still like the dual wheels :)
83ford
ford diesel baby
I know I just like duallys to lol always have
jhenegh
Truck Still Earns its Keep
Deerfield, WI
Here's one of those goofy SRW flatbed trucks
Works OK for that guy
83ford
ford diesel baby
I hate srw trucks with flat beds lol that's somethin i won't do I'll leave the beat up bed on
tke395
