Thin oil
Re3500
Texas
did a oil change 2 days ago
Oil is thin now not gaining any ideas what caused it so fast?
Re3500
Texas
Level stays the same dos not smell like fuel but how did it get so thin
nelstomlinson
Delta Junction AK
Thin? How are you measuring ``thin''?
Make a little viscosimeter: take a bottle and make a small hole, maybe 1/8" diameter, in the bottom. Pour a pint of unused oil in and measure how long it takes for the pint to drain out the little hole. Then take a pint of the ``thin'' oil out of your crankcase, pour it in and measure how long it takes to drain out. If the time is roughly the same, the ``thin'' oil isn't really thinner.
Just make sure that both the used and the new oil are at the same temperature. Let both samples sit in the same room overnight, maybe.
If the used oil drains through the tiny hole substantially faster, then we can start thinking about why the oil got thinner. If you aren't getting diesel in the crankcase, it's hard to imagine that anything would thin the oil in two days, or even two months.
Lance
Staff online
