I just purchased the Superior PressureRiser from Oregon Performance Transmission for my E4OD. I feel like a retard, but I can't find the TCM so I can wire into the plug.
It is behind the plastic cover to the outside of the emergency brake. You have to remove the nut from the engine compartment side. Nut is in the middle of the wire cluster.
P.S. I had to ask also, many moons ago. OkieGringo
