MIDNIGHT RIDER
- Joined
- Sep 29, 2005
- Posts
- 4,702
- Reaction score
- 142
I am in need of the four-prong pig-tails that connect to the rectangular tail-lights of a Ford chassis-cab ton (or bigger).
The set I have differ in the way they connect to the wiring from the ones on my 1985.
These have flat-bladed 3157 bulbs, as opposed to my 85's 1157s.
Also, instead of having actual wires hanging out to connect to the truck wiring, these have only a plug-socket.
In outward appearance, the newer ones are identicle to the 1985 ones.
If I can not easily come up with the proper pig-tails, I can bore a hole in the housing and simply run the wires through that hole, splicing them to the connections inside the housing.
Does anyone have a part number for these pig-tails and where can I find them ??
Thanks.
Thanks.
