thehollywoodjoe
So, the tachometer on my 94 just went out. The TECM is getting good readings, though, as I am lead to believe by the absence of limp mode and OD light being on. The truck still drives as it always has, but without any tachometer now.
Here's what I've checked into so far:
1. Tach sensor - Swapped with a spare. Both read between the 2-3k ohm range when tested.
2. Wiring - No chaffing. Followed it to the passenger side, then back to the drivers side. Intact.
3. TECM Relay - Swapped with 2 other relays - Not having signs of TECM non-power (i.e. limp mode).
4. Fuses - Under dash and engine bay distribution box - all fuses are good.
I have a wiring diagram that is telling me a WHT/PNK wire from the PCM goes to the tachometer...I'm wondering if there is a way to test the tachometer itself?
Also, I can't check for codes since I don't know where the CEL/SES light is. The truck isn't a 4X4, but the dash bezel has 4X4 stuff on it...wondering if the PO changed it, etc.
Anyhow, any suggestions on where to look next would be appreciated.
-Joe
