Tach question
Diesel_brad
Dunce
gilbert pa
What exactly does the tach use for a signal? Does anyone run an aftermarket tach? How/ what kind of signal did you use. And what model number tach did you use
13fcolt
former professional
Arkansas
keeping an eye on this one. i still have not replaced the tach i broke.
CDX825
filtration nut
Litchfield,Ohio
The factory tachs use a hall-effect type sender. So if you wanted you could use an aftermarket gauge. There are quite a few tachs that will work with hall-effect senders.
GenLightening
Yeah, it's a CHEVY!
Pukalani, Hawaii
It basically counts the teeth on the IP gear with a magnetic sensor and the pulse that's generated makes the needle move. There are some aftermarket units that run off a magnet that's gets attached to the crank or alternator pulley. Those don't usually work as well.
Diesel_brad
Dunce
gilbert pa
My reason for asking, is that when i swap over to my powerstroke, i want to keep my stock 86 tach but dont think the powerstroke uses the same signal
The PSD's use a VSS mounted in the rear pumpkin, triggered by a tone ring, that signal is fed to the PCM.
LCAM-01XA
my very own hell
That's for the speedometer tho... or do you mean the PSOM calculates the engine speed based on axle speed and gear currently used in the trans? Then how does it work with a stick-shift trans, the PCM or the PSOM have no knowledge of which gear you're in then, so the VSS signal cannot be used to determine engine speed.
dyoung14
Is getting worn out
spencer,tn
Pretty sure it wont work, so you will either have to buy aftermarket, or swap a newer dash and all that junk in
LCAM-01XA
my very own hell
the gauge cluster of the PSD trucks is driven by the PSOM, so maybe it's possible to retrofit a tach off a newer truck with a PSOM to drive it? I know the PSOM retrofit alone is possible cause someone on TDS did it in his van cause his replacement E4OD was of the newer type without a VSS cable so he needed the axle VSS signal to be translated for the PCM to understand it...
