Tach intemittently reads zero but reads fine when accelerating. Seems to happen only occasionally after a warm start. Any ideas? I pulled it and cleaned it checked resistance all looks fine.
sounds like she's dragging a leg per say... time to replace it. But BJ is right check the wires first because bad wiring can cause problems and with the age on these trucks wiring is a concern. You can only get the tach sender from FORD.
