Dbbitt
I have a 96 F250 PSD that I towed a 31 ft camper with this summer and while towing i suspected that it didnt have the power i had expected from the PSD. I havent given it much thought since summer but winter came and i had problems starting the truck in the cold. After finding a damaged wiring harness for the glow plug circuit i replaced glow plug wiring and the wiring for the injectors. i also removed and replaced the injector o rings. I no longer have the trouble starting in the morning but now i get heavy smoke in the morning until it warms up. again have not spent too much time on this. last week i picked up a superchips tuner and programed the truck, BTW no trouble codes before programming. after programming the truck i can only depress the accelerator pedal just so the ivs closes and the truck takes off like a shot full pull acceleration when i get up to speed get off the pedal step back on it boom like i floored it but only depressing 1/8th in or so. so after all this i cannot drive it this way i will get ill. now i have to figure out what is wrong that the program amplified the problem any help.
