rhkcommander
sorry to hear about the troubles, but it isn't easy treading in uncharted waters. Looks like your doing great so far
The problem is that those sheets are not totally correct for all applications. Remember that boost is a measure of restriction. So, technically, if you have a blower that pushes out 10 psi and a lot of work gets done on the engine and exhaust and that same blower at that same speed only produces 6 psi. (remember this is in theory only), the engine is going to make more power even though it shows less psi. I am not sure how much I can increase the size of the crank pulley. I know it will not be a lot becaus of how close it is to the waterpump pulley. So, I am going to run a shrunkin SC pulley when I have a chance to figure out how to get it together....but as for now, I have an idea that I think will work...and that is more than I had a week ago.
SWS
I was afraid you'd have issues making much of any boost with the M90 on the 6.9L. I've seen guys struggle to make 5lbs of boost with them on the 300's.
I don't know if you'll be able to go with a small enough pulley on the Eaton to make it work. It might be time for a jackshaft.![]()
Or maybe a gear drive set up like some of the centrifugal superchargers have.
I'd like to see someone try a Shelby GT500 H122 Eaton on a IDI.
He isn't looking for insane boost. Just a lil off of idle, which an M90 should give him due to being the positive displacement type.
None of the stock Eaton superchargers will produce an "insane" amount of boost.
I don't think he'll gain enough blower rpm with just a pulley swap. Now Add the pulley swap to a jackshaft or gear drive and he'd get closer.
Make sure to post lots of pics when you do your install.![]()
The Shelby H122 is a Hybrid between a twin screw blower and the roots.
I am looking at an 84(I think) dualley with a banks kit and an overdrive. If I can get it for this, I will add the turbo to the rear and make it a compound setup.
SWS
