Stuck lower injector body
BigRed94
Oklahoma
Hey,
I was wondering if there was any other way to get an injector. I tried grinding the threads and screwing back together, but couldn’t get it to thread on the injector lower body.
Any ideas how to remove it?
chillman88
Central NY
Have you scraped all the carbon build up off the injector bore above the part that is broken off?
Worst case, a 5/8" coarse thread tap can be threaded into it and a piece of threaded rod with a nut and some washers can get it out. Definitely not the best option, but it will get it done in a pinch.
BigRed94
Oklahoma
I got it out, with the advise of cleaning the carbon off the injector bore and grinding down the threads. Now I have the copper crush washer stuck in the bore. What do you recommend getting that out?
pwillis
