Struggling a bit with my wiring
Wheelhorsewilly
Marysville, Ohio
I am nearly finished puttin my truck back together, was trying to figure out where the glow plug solenoid was mounted and trying to figure out what wires connected where. Upon unwrapping the harness so I could clean it up a little, I found which wires were for the glow plugs, found several other plugs that not completely sure about. I also found a little plastic box about 3/4” square that is totally sealed by something the consistency of bubble gum except not sticky...what is this little box called? What does it do? Was mildly damaged and considering replacing it. Thank you
chillman88
Central NY
Sounds like the relay for the water in fuel sensor but without pictures it's hard to know.
riphip
Memphis, TN.
Wish my shop had that much working space ;Poke
That is going to be a beauty :Thumbs Up
Philip1
Northeastern Nevada
Na, it is bolted behind the cdr on the back of the intake manifold, factory turbo had a bracket on the passenger valve cover.
Selahdoor
Index Wa
If it's NA, it's behind there... The red wires you see there, are connected to it.
m2rtin
