Stressed over issue
Snickers
Hanford, CA
First timer here. I have a 2000 Ford F250 Super Duty 7.3 Diesel. I was driving my truck hauling my travel trailer on the highway when the engine suddenly STOPPED running. The lights on my dash lit up like a Christmas tree and I had to coast to the side of the road with no power steering. Once at rest, I tried to start it and it miraculously did. I just happened to be close to my diesel mechanic’a business. He ran a diagnostic test on it and it showed it needed a cam sensor replaced. Great, back on the road again! 75 miles down the road at a very busy city intersection, the EXACT same thing happened again! Thankfully again I was able to coast to the curb without anyone hitting me. This time the truck wouldn’t start and my truck and trailer were both towed to a local diesel mechanic where I’m now 30 miles away from camping destination. This mechanic also did a diagnostic test and now it showed “injector 8” needed to be replaced. It’s Friday, the part won’t be in until Monday. I’m patiently waiting for my truck.
My question is, has this ever happened to anyone? It’s extremely stressful, not once, but twice in one day. I’m very apprehensive driving it again, especially hauling a trailer. Any recommendations in walking me off the plank? Seriously, I’m hopeful this is the solution but any suggestions would be appreciated. (Sorry, about the length of this post)
trackspeeder
Stone crusher.
North Branford. CT
Most likely the IPR valve has failed. Many times the truck will start when cool or cold. unless it has completely failed.
As for the #8 injector. most scan tools will fail that one being a different type. I wouldn't bother with that. Deal with the IPR first.
lotzagoodstuff
Carmel, IN
Two things: when it’s cranking, make sure the tachometer is moving. Lots of folks apparently getting questionable replacement CPS right out of the box, you should rule that out first.
IPR is a certainly a usual suspect.
Don’t stress out. I’d get your camper to your spot and try to enjoy your time. If you have a competent mechanic, your old 7.3 PSD will get you home just fine after a little unscheduled maintenance. There are lots of examples of 7.3 PSDs like your with hundreds of thousands of miles on them operating every day.
Good luck
u2slow
bilge rat
Coastal BC
Best thing I ever added was a pressure gauge for the HPO system. A few bits from a hydraulics shop to get setup. (fitting, hose, gauge.)
If the HPOP doesnt/cant make pressure, the engine cant start. Not starting with good pressure is an electronics problem.
chessiesarebest
