Hey guys, got an 86 F250 6.9 ATS Turbo, with newer injection pump and injectors(Pensacola) with about 2500miles on them and today I was driving home an suddenly had a very potent smell of diesel and the motor acted as if it wanted to die at low RPM's. My first thought was air intrusion some were, but when I got home and popped the hood, my number 1 cylinder on driver side, closest to the rad(or 4 cant remember which side is what number) is popping fuel out between the steel/hard line and the 5/8's caps that go onto the injector. And its actually spraying out(about 8+ inches) and with the exact firing order of the injection pump. I undid the stock intake so it breaths right from the aluminum box that houses the air filter. The rough idle was from the diesel being spit into the intake. Im thinking clogged injector????? or?????? I tried tightening the cap but it was already tight. What do you guys think would cause this?
