zukinut
Ok, the zuk is down for the next 6 months at least. That means the ford wont be used for the next 6 months at least. With that said, what do i need to do, if anything, to make sure itll be ok. If it were a gasser i would know what to do, but with a diesel im kinda at a loss. It has a 66 gallon fuel tank that has about 10 gallons in it right now.
Thanks in advance,
Will
Thanks in advance,
Will
). Maybe evena couple additives, something for algae also. Then after sloshing around, drive the truck for ten miles to get all the fuel/additives to the injectors. That should cover that I think.
