Stock Lift Pump specs
wmoguy
Colorado
Does anyone know what the stock fuel pumps are rated for on our IDIs? Mainly I'm interested in GPM and at what pressure rating that rating is for.
FORDF250HDXLT
Maine & Oklahoma
Maximum Free Flow Rate (gph): 30
Maximum Pressure Range (psi): 5.75
Minimum Free Flow Rate (gph): 30
Minimum Pressure Range (psi): 4.5
according to the oem replacement at autozone part # 60278
they're all pretty close to this though.
if you want to upgrade your system,search out the carrier transicold pump here and grab one from Doug.
once you convert to electric,you'll never turn back,unless your a WMO burner of course (like your sc indicates lol),then id just stick with old trusty.
subway
be nice to the admin :D
York PA
thats funny the min and max numbers are the same, not much of a tolerance range to hit with flow.
jonathan
sullivan In
the book doesnt have a gpm but it says to test the pump by hooking up a vacuum gauge the the inlet side of the pump and start the motor up and if there is less than 12 inches hg replace it
wmoguy
Colorado
Thx! Yea I have a Carrier pump NIB I want to sell only because I burn WMO. Reason I asked is I was wondering if this would work out well for a fuel pump with my cocktail fuels. Based on the stock pump specs it would more than flow it, in fact I'd probably have to create some sort of pressure relief valve before the IP pump.
http://turbowerx.com/Scavenge_Pumps/Base-Model_Pump/Base-Model_Pump.html
