Nope. Don’t do it. It is set that way for a reason. And yes the longer truck will be able to turn the tires more since the longer wheel base is not as susceptible to the problems of a shorter wheel base. Spend some time Researching steering geometry. All front end parts from tires to ball joints will suffer. And when that happens it turns into a safety issue as well. Millions of dollars of R&D was put into getting each type of truck/car/suv the tightest turning radius possible while still being able to have parts last and be safe. Just gotta learn to drive what you got or buy a Prius.
