Stealth front receiver installed
lotzagoodstuff
Carmel, IN
About a year ago I bought a reciever for ten bucks at a garage sale. I have been planning to cut it up and mount it on the front of my truck, but I had to move the bumper up and out to clear the latest wheels and tires.
After lots of modifications to the stock mounting hardware and trimming a little bit of the bumper, I finally got it mounted. I put a folding license plate bracket from a 71 Impala over it so it's completely hidden when it's not in use.
I am pretty happy with the finished result. I didn't spend much money (less than 20 bucks actually) and although I haven't used it yet, I have used a front hitch on another rig to sneak a trailer into a tight spot.
88beast
pa
sweet install
i built mine into a brushgaurd you dont notice it too quick but when you do you ask why so strongly built
but i love mine its also great for pulling out youre idiot buddies when they get stuck so you dont gotta back in
also you might wanna look into a hitch step makes work easy
Fozz
Camarillo, CA
Don't know if you have a RV or not, but a lot of RVrs put a bike rack up front to haul their bikes. Another option for it since you got it.
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
Dumb question, but how's it mounted?
I have heard stories of people mounting these things to the radiator core supports and then having problems with the core supports... :(
Certainly looks cool ;Sweet
RLDSL
Diesel fuel abuser
Arkansas
I've never thought of that, that's a great idea! I've got a front receiver on mine and that would be a whole lot easier than dragging an extra trailer behind the 5er. When we want to carry the kids bikes , it means hooking up a utility trailer behind the 5er because I have a mobility scooter that has to go too, but if I can stick bikes up front , I have an electric lift for the scooter that goes in the hitch on the back of the trailer. Without that extra trailer I don't have to worry about getting into spots where I can't backup ;Sweet
grog85
novi,mi
That is a slick setup, I like the hidden aspect of the plate. That really looks good.
Knuckledragger
Payson, AZ
I might put one on just to use the step feature. I'm 6'3" and still can't reach everything I want in the engine bay. a step would be just the ticket, and I have wanted to move trailers (in very tight spots) from the front from time to time. This is just what I need, another project.
lotzagoodstuff
Carmel, IN
I spent some time thinking about how I was going to mount this, and this isn't the final version, as it's ended up getting mounted higher on the frame brackets for the bumper. I've got a little more to do before I will pull it and fully weld everything, but it's pretty stought even as is.
Keep in mind that I wanted it to be very strong (front hitch mounted winch possibility) and I wanted to leave room for a front mounted intercooler should I decide to turbo charge my truck in the future, and I accomplished both of those goals.
In the end it was actually pretty simple.and I could draw up a sketch on how to make another one if anybody wanted to duplicate one. If you don't have a body lift and/or don't need to move the bumper up and out, it's a walk in the park. Two plates with some slotted holes for adjustment, a little welding and you'd be done.
MIDNIGHT RIDER
I know ----- old thread.
Anyway, instead of one of those **** little hitch-steps, why not one of those big luggage carriers poked in the front, maybe with a custom-built deck to walk around on; thus, you could just climb around all over and not have to worry about missing that tiny step.
Another plan I have stashed away in the deep recesses of my mind is to put receivers at each corner and fix up some of those big goose-neck trailer jacks with receiver-tongues; thus, I could put things way up off the ground with just a bit of cranking; safe and solid too.
