Stalling, starts right back up?
Marks Garage
Southampton, NJ
02 7.3 powerstroke 60,000 miles. Stalls some times everyday, but hit the key and it will fire right back up and run for hours. Maybe a cps, does that stand for crank position senser or cam position senser? Thanks guys.
Mike
Stroker
Cora
CPS stands for cam position sensor.... sometimes you will also see the acronym "cmp". But with what you are giving for details, I would first say that it is the CPS.
Other things to diagnose, how many miles on oil/filter change, when was last fuel filter change.
Marks Garage
Southampton, NJ
I just changed the oil 2000 miles ago along with the fuel filter. 3 days ago I drained the water seperator. I will change the cps next. Will post if that fixed it. Thanks Mark
93turbo_animal
Marengo,Ohio
CPS would be my guess but I did just read a post about a guy that had a die and start right back up randomly problem his turned out to be the EBPS so if you want to try that first I beleive you can just unplug it and drive around for a while you'll have a cel but thats all and its free
Mike
Stroker
Cora
EBPS is exhaust back pressure sensor, I have never seen the EBP cause a truck to die. It will close the exhaust back pressure valve at improper times.
93turbo_animal
Marengo,Ohio
I've never heard of it before but the guy had been having this problem for a while and I guess he got to lookin and seen that it looked like water had gotten in the sensor truck died on him so he unplugged it started truck plugged it back in and died so he replaced it and all has been good now strange I know but just another sensor you can check by just unplugging it then cross of the list if it don't help
PSDfreak
Diesel-a-holic
Newcastle & Chico, CA
Yep been following that guys problems too...weird that it turned out to be that, but its something to keep in the back of your head if it turns out not to be the CPS...
Good Luck,
Casey
