spray on bed liner on running boards?
Russ
Idont do injectors
New Brighton PA
The paint keeps peeling off of my running boards(smooth aluminum), and I was thinking about using some off the shelf spray/roll on liner material on them. What are your thoughts on how well it would hold up, and how slippery would it be when wet? Thanks.
Double-S-Diesel
parts seller
derry pa
so far so good on my rockers and door jambs.
had it on the other truck in the door jambs seemed good after 6 months
sassyrel
iowa
clean the alum--some half coarse sand--put on liner--throw on some sand--zero slip--
jwalterus
Made in America
Garrison, ND
I don't see why it wouldn't work, we coated a leaky aluminum boat with the stuff from wally world (the gallon can for 40 bucks) on the outside and then used it all summer with no leaks
but why not use rubberized trunk coating? it's a spray can for $7, and it goes on rough and non-slip
