Sound the lights on bell!
BigRedWeather
Lexington, KY
Can you believe anyone wants to add one more reason why the lights on bell would sound, when most people would like to kill the thing all together?
Well, I have a circuit. If that circuit is closed and the driver's door is open I want the bell to sound. In addition, if the lights are on or if the key is in the ignition and the driver's door is open, I want the bell to sound.
Knowing this can be done (and I am sure it can) is one thing. Being able to describe which wires to modify, will be quite another.
Thanks in advance,
BigRedWeather
BigRedWeather
Lexington, KY
Lock the keys in your truck one too many times?
Keys left in the truck is covered by the stock warning bell. I want to also hear the bell when on additional, non-stock circuit is closed.
It would be a big help if someone know where that bell is located, so I could gets the wires leading to it. It is very hard to located by sound or feel, and it isn't in the factory manual, that I can see.
BigRedWeather
rjjp
Needs to go test
Clare, Mi
Under the dash straight above the drivers side on the transmission tunnel, should have a seven pin connector on it.
(the dinger out of my truck is setting next to me right now...)
