Put new socks and shoes on the ol girl!
What wheels are those? I've been looking for something like that.
Procomp extreme 17x10s I believe.What wheels are those? I've been looking for something like that.
Usually not a huge fan of chrome but it might grow on meI thought they looked like procomps.
I just had a customer with an explorer with similar ac issue (if I am reading your post correctly). His truck is before they went to cabin filters. Anyway after a lot of fun, finally though to use a camera stick down and found debris (mostly dog hair) blocking a lot of his evaporator. I found a "mod" to allow it to accept a cabin filter and while I was in there I scraped off the hair and crap. EwwDrove it lol that's all I've done latley I gotta figure out how to make my ac blow harder it's cold but you can barley feel it hitting you so it just keeps you from sweating it doesn't keep you cold.and I gotta figure out the death wobble it has happend with 2 diffrent sets of tires and 2 different front axles I'm stumped lol
Sent from my Iphone using Tapatalk
I just had a customer with an explorer with similar ac issue. His truck is before they went to cabin filters. Anyway after a lot of fun stuck a camera stick down and found debris (mostly dog hair) blocking a lot of his evaporator. I found a "mod" to allow it to accept a cabin filter and while I was in there I scraped off the hair and crap. Eww
My truck is also giving me death wobbles even after replacing worn balls, tie rods, and box. All had excessive play! Still slight wobble although not as bad.
I'm going to be replacing my worn carrier as well as shocks and front wheel bearings as they all also need to be done. Truck has over 250k and I have no repair history on it.
I've also read of people adding a steering stabilizer but I think that masks an issue of the truck having other issues.
Sent from my LG-H901 using Tapatalk
I gotta put my cold air tubing back to pull form behind the grille. How much of a difference did this make? I recall mine made a difference, but very small (under 100* but noticeable?). Towing the other weekend for the first time since new pump and the truck was very EGT limited. Starting up one hill on the highway (rolling hills, not serious grades) I was distracted talking for about 1-1.5 seconds before beginning my OCD monitoring of gauges and pyro was as 1200 just maintaining 65-ish MPH. Quickly backed out and maintained 1100 or so and gave up a bit of speed. Very little margin for error with my current setup. Really needs an intercooler.
In any event, put a few hundred miles on the truck today to pick up a wastegated turbo that will fit the ZF5 I'll be swapping in. Applied a few heat and PB cycles and snapped two studs. One is blind... this should be fun. Could be worse I guess. Hopefully once it's done it'll be an improvement over the first generation Banks on there now.
